Yes
The upper two corners are rounded and there is a very small valley making sealing less than ideal at those two spots but a good sealant should handle it.
Aftermarket LS heads also have 5 bolt holes that can be used to pull the cover up tight.
https://www.dropbox.com/s/9yuo17x9ozhwn ... .JPG?raw=1
Those are the ones I meant.
The 4 studs under the intakes(as well as the outer 4), on the aftermarket 6-bolt ones aren't likely relevant.
The newest DI heads eliminated all but the end ones, of the 5, but should still hold a cover.
They reversed the valve layout too, but with a custom cam, intake, header, not an issue, I'd think.
And, with LS3 stuff at 340cfm@.500 that should suffice.
Thoughts on how the short pivot length on the LS rockers, and relatively high lift, works as well as it does? tip travel?
And, thoughts on shifting the bore centerlines in the block, to make "3 groups of 2", more closely matching the head segments?
A .040 over, split .005/.035 is still only taking .020 from the thrust side. Less if the bores are also shifted to the driver side.
All pending sonic check, of course.
