Found this on www.coatesengine.com/lookmo...
I found it a little hard to believe. Comments Anyone?
It says. "The first and second laws of thermodynamics dictate that any increase in compression ratio will yeild a disproportionate gain in fuel efficiency over power generation".
"Raising the compression ratio from 8:0:1 to 11:0:1 will add just 5 percent to the engines power but decrease fuel consumption by 20 percent if all the other factors in the engine remain constant.
They add "This is the reason the cars of the mid 70s were so fuel thirsty, the mind set then was to lower the comp ratio to reduce oxides of nitrogen (NOx) emissions".
