It is an iron head. The intake manifolds are specific to the iron head; they will not fit on the alloy version.
The seller also states that the cam needs replaced (wiped out lobes) so there's an added expense.
The block is a 76DA casting; an alloy head will bolt on.
Wouldnt bother with any iron heads, way too heavy to start with, its too expensive as well. Ive got a couple of alloy heads and a spare block and crank. I run a blown 200ci Xflow, pretty good thing. crossflow blocks with standard bore and minimal corrosion are getting hard to find.
