About to buy an Autolite 2100 for my 250/AOD project. As you well know a good one isn't cheap and neither is time on a dyno, so what do you think I should start out with? and if you got one, what are you running? Here's the details: 250, 40 over 255 pistons, Classic Inline's 2V Performance conversion, 1.75" intake and 1.50" exhaust valves, approx. 9.3 to 1 compression, 277 hyd cam w/ 112 degrees lobe separation, headers, AOD with 3.50 Truetrac posi. It's going to be a daily driver with a lot of freeway time.
I'm thinking 1.14 venturi that are common on 289 because the 250 is modified. Mike suggets a 1.02 and thinks a 1.08 is too big yet alone a 1.14 and he forwarded some links, which I shared below. CFM calcutor suggest around 300 cfm @ 5000 rpm 80% efficiency 255 cu in. Subsitute 289 for 255, we get about 340 cfm.
http://www.4secondsflat.com/Carb_CFM_Calculator.html
http://falconperformance.sundog.net/compcalculator.asp
bore 3.72 (.040 over)
stroke 3.912
cc volume 66
head gasket .050
dished 4
80% @ 5000 rpm = 295 cfm
Food for thought ( Thanks Mike! ):
Read our tech article, "A Day at Pony Carbs"
http://classicinlines.com/PCdyno.asp
And on 2V Carb Swaps http://classicinlines.com/DynoSwap.asp and
http://classicinlines.com/Dyno3.asp
Part 1 & 2 viewtopic.php?t=52903
Part 3 & 4 viewtopic.php?t=54061
http://classicinlines.com/dyno3A.asp
Somthing I found:
"Now is a good time to understand carb flow ratings. 2 barrel carbs are rated at 3 inches of vacuum and 4 bbl carbs are rated at 1.5 inches. A 650 carb on a 358 cubic inch engine will seldom see 1.5 inches but a 350 carb on the same engine will frequently see 5 to 8 inches. At 7 inches of vacuum the 350 carb is really flowing about 430-440 cfm."
http://www.camcraft-cams.com/index.php? ... rrel-carbs
So, what do you all think? 1.02, 1.08, 1.14, 1.23 or Holley 350!?
stroke 3.912
cc volume 66
head gasket .050
dished 4
Somthing I found:
