Autolite 2150 Info
CZLN6
2K+
Howdy All:
I was doing some research for another forum project on comparing internal deminsions of the Autolite 2100 and came accross this site-
http://home.earthlink.net/~bubbaf250/2150carb/carb02b.html
It is specifically about the later Autolite 2150 on a big block, but the descriptions and photo illustrations are going to be very useful to anyone working on an earlier Autolite 2100- especially the cluster functions. You will still have to measure by hand, but it's good to know what you've got to get to where you want to be.
The non-adjustible internal functions on a 2100 make it somewhat less tuner friendly than a Holley 2300.
Also note the explanation of the variable air bleeds and external vacuum source power valve convinces me to stick with the 2100 version.
Now all we need is a good source for new jets.
David, the article of the autolite carb is very informative.
Does someone make an adapter to fit the smaller thread holley jets into the autolite carb?
Pony carburetors probably has autolite jets available.
Again very good post. Thanks
