FYI.....
Howards Cams – 98110
130# @ 1.800” Installed
300# @ .544” lift
314# @ .588” lift
318# @ .600 lift (max.)
313# spring rate
Coil bind @ 1.140”
O.D. 1.290”
I.D. 1.055”
Howards Cams – 98112
135# @ 1.800” Installed
320# @ .544” lift
335# @ .588” lift
339# @ .600 lift
348# @ .625” lift (max.)
340# spring rate
Coil bind @ 1.100”
O.D. 1.207”
I.D. 1.072”
Both use their 97161 steel retainers
Set of 16 springs is in the $160.00 range for either set.
Retainers are in the $50.00 range for 16.
Jeff
300# @ .544” lift
314# @ .588” lift
313# spring rate
Coil bind @ 1.140”
O.D. 1.290”
I.D. 1.055”
320# @ .544” lift
335# @ .588” lift
339# @ .600 lift
340# spring rate
Coil bind @ 1.100”
O.D. 1.207”
I.D. 1.072”
Jeff
