You can improve your MPG if you're not a hot-rodder by increasing (slightly) the exhaust backpressure. This is especially true if you've already installed a hi-perf cam with lots of overlap.
Here's why, based on Ford's FE engines (big blocks):
The exhaust manifold can be tuned to cause some backpressure during certain RPM ranges. This backpressure reduces the "feed-thru" of unburned gases that happen during overlap. If a very low-restriction exhaust is used, the lack of backpressure improves the breathing at higher RPM, like over 3000 RPM, but some of the gases slip thru easier at low RPM. (Witness the newest hi-perf computer-controlled engines with "X" exhausts: they use gates to block a whole exhaust pipe at low speeds just for this reason, forcing both sides of the V-type engine to use one pipe below 3000 RPM. It opens above that for better HP.)
Ford used the "log" manifold on these I-6 (and FE engines) to improve backpressure and lower production costs. On the FE, the pulse timing of the exhaust is such that the exhaust manifold is "restricted" at low RPM by high pressures from the last 2 cylinders on each bank. At higher RPM, the overlap causes inertia in the gases and the pulses smooth out, becoming a hot flow. This is one reason why the old 390 delivered surprisingly good MPG at around-town speeds, while the later 400/429/460 did not: there is always a slight "flat spot" in the log-manifolded FE engines, right where the transition is happening from pulsed flow to hot flow. On mine, it's at about 1500 RPM. On my 3.3L I-6, it's at about 2200 RPM.
On the I-6, low backpressure for HP is helpful above 3300 RPM, for sure. But, low backpressure at 2000 RPM allows about 3 degrees of overlap to go to waste. Adding a slight restriction (like a standard muffler instead of a straight-thru type) will improve both the torque and MPG available in the range of 1500-2000 RPM, assuming a standard cam. This is because the 3 degrees of overlap will have to push against the higher backpressure, and it won't flow so well.
It's likely also true with long-overlap cams, but I don't have one in my cars for testing. As an example, though: in my motorhome (a log-manifolded Dodge 360) I changed the straight-thru 3" muffler to a conventional 2-chamber side-by-side oval muffler. My steep-mountain climbing speed improved from 38 MPH to 44 MPH in high gear and the MPG on the highway went from 9.4 to 10.1, steady. My hill-climb MPG went from 7.8 to 8.8 MPG, consistently.
So, if you're in the market for a muffler and better MPG, look into a nice oval-shaped Walker or similar type.
