relevant earlier post:
keep it simple - run some Compression-calcs' for head chamber volumes until they seem to match your target CR, then consult ..
actual volume measurement is best but can be tedious, my machinist simply subtracts how much has been milled from the OEM specs on the head which is OK
IF head is uncut already... Typically, milling the head .010" will result in an approximate reduction in volume of 2cc's.
from CI pages:
'actual chamber volumes may vary considerably, which means they must be re-measured (cc'd). The key is to measure carefully and record the results, then mill the head accordingly to obtain the desired compression ratio.'
typically, milling the head .010" will result in an approximate reduction in volume of 2cc's. For example: if your cylinder head currently has 62cc chambers, and you want 52cc's, you would need to mill .050" off the head to reduce the chamber volume by 10cc's.
it's said small block six cylinder heads can be safely milled .090".
DODE _70 Mav' 170 'closed chamber ' head OEM @ 54cc's measured and typical later 200/250 @ 62cc chamber head.
'63
moredoor wagon has a C8DE Maverick 170 with a D7DE head
cut @ .070 (@ 48CC Chambers) with an early
steel shim 144/170 - 3.75 bore head gasket ( @ .025 ) ( 200/250 = 3.81" bore) yields
up SCR @ 9.5 or higher... . (Unfortunately the
thinner steel shim gaskets are virtually
unobtainable for the 200/250 3.81 cylinder bore ) BTW - flat top 170/144 pistons skew the compression calcs' results from 200/250 recessed piston cc's measurements.
The '63 170/T5 is plenty adequate for modern driving
with @ 93 Octane (U.S.)
