while over-simplistic, its said the cam is the heart of the engine, and it certainly does dictate (along with engine volume) what lifter/porting/exhaust/carburation mods you make to support it. I'm prepping again to build my first engine, and I want to verify my needs as it were. It's my 67 mustang, 4cyl t5, and I love coming off the light hard (that's what makes getting groceries fun), so I'm assuming I want a low range cam in the 110* range as I don't know how much I'd like a real choppy idle of a 108* (has anyone used one?) but I'm not sure how low my rpm range should be really. It's hard to gauge off a 'if you like this kind of driving get this' scale.
One of the things in the CI tech section shows for highway driving and passing, the 112* is a better choice. Will a t5's increased gearing variables mitigate a lower duration cam? Or will the lower first gear (depending on rear/tire combo) make up for a lack of lower range torque in my 112* cam? I know a classic pony isn't made for high speed driving, but sometimes you need a little bit. I currently have:
264/274-112* Hydraulic Dual Pattern Cam (http://classicinlines.com/proddetail.as ... 264-HDP-12)
which looks like a good toodling around cam, but it's hard to guess how much of a loss of fun at a light there really is. It will have a ds2, so that should help the oomph at all ranges.
so I guess getting around to what I'm asking isn't so much a 'what cam' thing, but rather what range given my drive train accoutrements and predilections. Increasing carb and cleaning up flashing isn't an issue, but I don't think porting (above bubba pocket porting maybe) is in the cards.
I'm also assuming that the 112* would like the 302 springs and one piece retainers, but a low range built not as much? Not that it would be detrimental, just not as valuable with less rpms and less valve float? Don't want to waste resources that are at least trouble to find.
