I didn't do the wire dance. I didn't have time to play and I thought it best to just get things right with the distributor. I took my time, set the engine to TDC, marked everything, everywhere along the way, paid close attention to moving the "Entire" distributor. After moving it, I could see that the new position it was in, would be the correct position, in that, I thought, that an engineer, designing for form and function, would place the distributor in the exact same place, with the vacuum can/diaphragm just about parallel with the block, allowing for movement/adjustment and still allowing for connection of the maleable 3/16" steel vacuum line. The hardest part was getting the distributor hold down bolt to move. A good amount of PB Blaster was a great help with that. One Snafu! ...while doing all this, I stupidly left the battery connected, and I stupidly left the ignition key in the "On" position...
opsie: I believe these two overlooked steps, procedures, are the culprits behind the reason why my ignition coil got fried, specifically the secondary windings.
The next day, I borrowed my girlfriend's zippy 2010 Honda Civic LX Coupe and went shopping. I purchased a New Accel Super Stock Chrome Canister Ignition Coil, Part #ACL8140C, $36.99 + Tax... which, by the way is probably, and surprisingly, for being an AutoZone purchase, the Best Price you'll find anywhere, even better than Ebay. With my military discount (Veteran), Grand Total was $35.95.
Let me tell you, after moving your distributor around, and trying to get things right, and thinking that you did... and then attempting to start your car and test your work, and hearing only the sound of a spinning starter... it's very disconcerting, disturbing, and depressing.
With the new coil in place, and after triple checking that everything was in place, the car started right up and after fine tuning the timing, I was ready to get back to working on my carburetor replacement project.
:thanks:
to All who contributed their Knowledge and Experience. I would appreciate too if you all kept an eye out for my posts regarding the replacement and tuning of an Autolite 1100 Carburetor
:help: .
