Carb head combustion chamber question.
pmuller9
2K+
Supporter 2018
MechRick":2omuvebz said:
pmuller9":2omuvebz said:
The Crower 284HDP (19205) .509”/.517” 220/222 284/290 110deg
Based on my experience with Comp's 268H (219 @ .050", 110 LC) that *might* lope a bit with a carb intake. Depends on idle RPM.
The lope went away with an EFI intake and aftermarket (Megasquirt) fuel management.
The OP has made an intake manifold with long runners that will help with intake port reversion at low rpm similar to the EFI intake.
It should tame the lope so there is very little at a slightly elevated idle.
I like FTF's idea of "Dial a Lope"
THE FRENCHTOWN FLYER
Moderator
Supporter 2020
Supporter 2018
TRUE STORY
I was in a meeting where lots of people smarter than me spent a long time discussing ways to get idle quality up to a "10" on our engines. And by "10" they meant a smooth-as-silk-electric-motor-smooth idle. I finally couldn't contain myself any longer and said, "Guys. You have to know and recognize your customer base. Sure, some folks will want a 10 idle. For another whole group of customers a car with a 2 idle will be wonderful. Heck, when I was a teen some guys would pull a plug wire off just so when they pulled into a drive-in other hot rodders would think the engine was "built"."
Crickets
GPGoverMPG
I looked at the Crower Cams web site and I'm pretty sure that's gonna work. I know to disregard the RPM rating. I'm going to play with some numbers tonight.
guhfluh
THE FRENCHTOWN FLYER":23rvgori said:
That is very interesting, and not surprising I guess. So with today's electronically controlled everything (traction control, ride control, engine management control, ABS, creature comfort controls, etc.) how long will it be before somebody comes up with an "idle quality" control.
I can picture it now. Out on a ride with the wife or an important client? Dial in a smooth-as-silk idle. Going to the local drive-in burger joint on cruise night? Dial in a lumpy lope. Just by varying the amount and timing of the "squirt" going to each individual cylinder.
Probably even more effective with today's DI engines.
Hey, that could be my next condo in the Caribbean!
They already have it out there in "ghost cam" tunes on vehicles with variable cam timing.
I found about the same with my Comp 268H cam. I can make it lope by leaning it out and retarding the timing at idle. I can make it smooth as stock by richening it up and giving it vacuum advance at idle. I've actually been thinking lately of going to a bigger cam...
pmuller9
2K+
Supporter 2018
It will give you a nice wide power band with the ported head.
Abandoned Bronco has an identical cam from Erson and it pulls smoothly from 1000 to 5000 rpm.
He is currently battling an issue with the engine running at WOT
Waiting to see what the final combustion chamber volume ends up being.
5K+
I cant sppon feed it to you, but the secrete is that duty cylce over lap hurts idle and wide open throttle performance. The muddy waters to this are other things entirely.
Port on port carburation isn't being done here, but the same basic principals apply. A port on port discussion is here
viewtopic.php?f=2&t=77685&p=608580#p608817
The principlas are two fold.
1. Only when overtly large, and independent runner, port on prt carb systems, does an engine respond to pulse tuning. Pulse tunning allows more fuel to get in with less air flow.
2. On all other Non port on port Examples, you have to avoid earlier production common USA I6 and V8 2 and 4-bbl thinking. Not that its bad at all, its just that it focuses on cost and undercarburation, and using cam design is a crutch as opposed to to sizing the the average carb venturi areas to the total the engine capacity for a given rev range. Mike Stacey from Chrylser Australia Party found that port on port worked best, but that 4-bbl long branch intakes like the Dutra 4-BBL also worked. So did a Repco Ford Falcon development engineer. Both realised that it was carb venturi to engine size relationship that made up for a lack of port on port intake design. A great deal of that information filtered into the early 4-bbl Big Six experimental intakes, showing a real understading of how to make a n I6 idel, and perform with very big carbs.
"Pulse tuning" for carbs only happens at about 11 to 18 feet per second of air flow, so you have to go really REALLY big to pulse tune. Forget all that CFM flow rate hocus pocus. Well, not exactly forget, but don't get het up on it. My advice is to Only focus on the ventrui area required to match the peak power rpm for the capacity of engine. This process is called Dimensional Analysis, and all great benchmarking engieers use it. They just don't tell you they benchmark.
Oversizing is okay if you work within known limits. Then engine will rev well above the peak power rpm band . 5500 rpm is a good figure to punt for. Twin 1.08's might work, but other bigger Autolites and Motorcrafts can and do work better, without hurting idle.
viewtopic.php?t=41010
Bret":2b6p2kcs said:
I found the flow rates for MC2100/2150 2 barrels.
This information comes from CJOFFROAD.COM. That website has a ton of information on these carbs.
2V 2100/2150 at 3"Hg. Venturi size listed first.
0.98 = 190 CFM
1.01 = 240 CFM
1.02 = 245 CFM
1.08 = 287 CFM
1.14 = 300 CFM
1.21 = 351 CFM
1.23 = 356 CFM
1.33 = 424 CFM
In order to compare these carbs to 'metric' carbs, here is a conversion list. Remember that venturi size is not the same as bore size. In example, a Weber 32/36 has venturies of 26mm/27mm. The MC2100/2150 carbs have syncronous butterflies, just like the Weber 38/38 DGS carbs.
0.98 = 24.9mm/24.9mm = 190 CFM
1.01 = 25.6mm/25.6mm = 240 CFM
1.02 = 25.9mm/25.9mm = 245 CFM
1.08 = 27.4mm/27.4mm = 287 CFM
1.14 = 29.0mm/29.0mm = 300 CFM
1.21 = 30.7mm/30.7mm = 351 CFM
1.23 = 31.2mm/31.2mm = 356 CFM
1.33 = 33.8mm/33.8mm = 424 CFM
THE FRENCHTOWN FLYER":2b6p2kcs said:
Thanks for the info. This info is often sought after. It should be on the FAQ post above.
Remember that four barrels are flowed at 1.5 "hg. So these flow numbers do not equate to 4V flow. To convert divide by 1.41.
So, for example, a 190 2V would be equivalent to a 135 4V.
A tri-power using 3 of these 190s equals a 404 cfm four barrel.
For idel and max performance, Peak venturi size (ie, if a 1.08 is gonna work better than, say, a 1.14, 1.21 or 1.23 or 1.33) is goverened by if the runners are isolted from one another. If they are, the duty cycle is improved, and you can always go bigger to an optimum size from the Weber carb chart.
Then you can multi layer from two barrels to met the same target 1bbl cross sectional area.
So if one 40 mm venturi per barrel is what you need to make power to 4600 rpm on a 300 six, you can also use two holes of the same equal area. more tahn one barel per port has been done with huge success.
Any time you get an idealised venturi area in the Weber chart, you can Root 2 it to 1.414, and find two 28.29 mm venturis will do the same thing.
This is exactly what the 8bbl aftermarket non Max Wedge intake below does. It puls tunes 6 cylinders by using 12 venturis. Its overkill, but it worked right to 10000 rpm and over 600 hp, and with valve lifts of 900 "thou".
https://www.hotrod.com/articles/mopp-10 ... ing_insert
And the Jim Headrick Cotton Perry from Georgia was a Sportsman-class, 310 cube 67 M/Elim Chevy II driver who did it all with its three huge 780 cfm 4-bbl DZ option CrossRam carbs.
The way it works is that if you isolate, you can then increase carburation without hurting idle. Ford did this with the bigger spread bore carbs on V8's to countact the cost of running multiple carbs. They then had a heap of other matters to contend with to control idle. Cam design was seen as the great soltuion.
IMHO, Shared intake pulses always hurt idle. To improve shared plenumb or siamesed port engines, you have to look at ideal sizes from historical non USA engines, becasue the USA I-6's and V8's are frequently undercarbed, and don't idle well because of intake restrictions or card size restrictions.
Generally, first in the minds of North Americans is to increase port velocity, which is what actually Causes idle quality degradation, and peak power loss. The smaller the ports, even if really nicley gasflowed, the more the idle suffers. Its big ports with big cams and insufficent carb area that causes a lot of idle and wide open throttle issues, which Detriot covered over with secondary barrel operation.
Going to a bigger carbs on non isolated runner systems can also work darn fine. Although absolulety none, nada, nil, nein in line six or V8 US production performance engine ever ran port on port induction (exception...some British build, US order 289 GT40's did)
Non port on port Examples:
1) The work the late ex Ferrari engine designer Aurelio Lampredi did on the six cylinder Fiat 2300 in the 60's (two 0.9375 " venturi 2-bbls) , and
2) David Vizard did on the big 44mm 1-3/4 inch 2bbl venturi carbed 145 hp Mini 1275 four cylinder car his daughterSamantha piloted in the 80's , and
3) the 245 hp Holden XU1 Torana with three 48 mm venturis three 1-7/8"did in 1973 showed this.
All these cars cars idled a lot better than many realise despite realatively small capacity, and made exceptional power with really big cam duration.
For example 1, 2 and 3 above, you have 138, 78 and 202 cubic inche engines. On a carb venturi area per cubic inches of engine basis, they all have twice to three times as much carb venturi area than a set of 1.08's on a 300.
Be prepared to experiement with bigger venturis, and trst that the long runners will help the idle and wide open power situation a little by attenuating the pulses to the venturis and carbs. I'd say look around for the bigger A 2100's and MC 2150's.
GPGoverMPG
Helping daughter with tires on her car and didn't get to play with a DCR calculator.
I did find the following Snider Cams:
hyd
284-88H
284/288
224/232 @.050
.512/.512 1.6 roller rockers
108 LSA
Solid
292-96F
292/296
258/262
.584/.584
108 LSA
.020 Lash
I'm still in control of my compression I'm at 81cc and the head has not even had a clean up cut done. I'm for sure going to run the 1.08s to start and break the motor in. I've already run them on my truck one at a time to make sure they work well. The split plenum on my intake will mean setting them up like the carbs on the bikes I once raced and getting them sync'ed right. I'll also be running twin wide band gages to help. Can always go bigger if I get feeling frogie. The 284-88H is a lot like a cam profile talked about earlier. I would say a 10:1 compression is still available if needed. I kind of like the solid idea just cause no good reason.
pmuller9
2K+
Supporter 2018
The Schneider 284-88H will work.
It has 12 degrees of overlap and will have some lope at idle.
It will also work with a 9.5 compression ratio, not 10.
The Schneider 292-96F solid cam has way too much duration for your engine.
GPGoverMPG
Right, that 292 was looking crazy. The 284 seamed right in the wheel house. I still want to play with some calculators for the knowledge. I have my 455SD '72 Ventura that runs race gas. I bet with the right cam I could afford to street it a bit. I think this truck is gonna be nasty. I was doing two wheel burnout's to day. Keep them lit up into third as is. 33-12.50X15s I wish the cash was coming in faster so I could accelerate this project. Rookie driver in my own parking lot. With the built motor I won't play anywhere it could hook up.
GPGoverMPG
Just a quick up date with a picture showing stock valves and the new 194/160 from SI valves. They have not been set by the machine shop yet but you can see the difference.
Moderator
Supporter 2020
Supporter 2018
OK so far. I'd take the chamber surface to a sheenyier shine. I also like to slap an old head gasket on the head to prevent putting grinding marks across the head face if the grinder gets loose and does its dance.
pmuller9
2K+
Supporter 2018
Looks good
Have you decided on a camshaft?
The Schneider 284-88H you suggested would be a good choice.
GPGoverMPG
Yea that's the cam I'm going to run. I posted the picture so everyone can see the difference in the intake valves. I ordered some more sanding disks so I can finish the chambers and they must have gotten on the slow boat. I'm goin to need springs and retainers then it's off to the machine shop.
GPGoverMPG
Alright I will. Thank you. I'm going to set up my cc'ing rig this morning and double check my volumes. I'll have the machine shop set the valves and install the screw in studs then I'll pick it up check the volumes and I should know how much the have it milled. Then it's measuring twice and shimming to get the springs right. It's going to be some time before the bottom end is ready so I'll store the head with the keepers off.
GPGoverMPG
I was trying to play with a dynamic compression calculator and it asks for the intake lobe center line. I did a search of this site and didn't see anything about how this number is reached. The 284-88H cam is split duration and they also have a solid cam that is very close and I wanted to see the changes to compression. So how do you get the intake center line without a cam card? Thanks again
pmuller9
2K+
Supporter 2018
The 284-88H cam has a 108* lobe separation angle which means if the cam is installed in a neutral position the Intake Lobe Center will be at 108* ATDC and the Exhuast Lobe Center will be 108* BTDC
The cam card is going to ask you to set the Intake Lobe center at 104* ATDC which is 4 degrees advanced.
The intake valve will close at 66* ABDC based on the 284* advertised duration.
GPGoverMPG
yea I thought that was the deal must have fat fingered the keyboard several times. I'll try it again. With my new setup the heads cc at 79cc's I stopped waiting until the valves are installed.
