Carb score
cr_bobcat
Supporter 2018
Supporter 2021
So I scored a 1.21" 2150 on ebay for $30, and 2 more 2100 ( unknown venturi) on craigslist for $100. Oh, and I snagged a black lokar pedal on ebay forn $100. The 2 unknown carbs are coming with a buttload of jeep parts including a power steering pump and a york a/c compressor. If nothing else i should get my money back if it doesn't work out :beer:
Soany clue how interchangeable the jeep versions are with our setup?
all the autolite 2100 carbs will fit any ford it that bolt pattern, they are like the 2300 holleys.
I was figuring that would be the case. Seemed like there was only 2 base patterns between the 2100 and 2150. I assumed that i was pretty safe. Was hoping to be a rebuild kit or 2 away from happy.
So tell me about the York a/c compressor. I'm hoping i got stupid lucky and stumbled onto something. Hoping that it and the power steering module are relatively easy to recondition and reuse!
:beer:
cr_bobcat":3jodbx76 said:
.So tell me aboug the York a/c compressor. !
:beer:
depending on which model - i could use it to pump me some 'on board air' to run a ratchet or other pneumatics.
So the 2 carbs were both 1.21 venturi, MC2150s. The price was right though and I can keep my eye out for an economical 1.14 in the meantime. This will at least get me going once the head is done at the machinist. I can hot swap later when the opportunity presents itself.
I haven't had a chance to dive into the box of stuff he gave me. There's supposed to be some linkage/brackets in there on top of the PS unit and the A/C compressor. Should be able to sell the remainder of the stuff without too much problem though.
