Cautionary Note - 1904's
powerband
2K+
I took the winter-dormant Tri-Power 250 out in the unusual warm weather the other day. Cranked and pedaled' the carbs to get some fuel in the no-choke mod'd 1904's and it fired up as usual. Carefully warmed up the 250 and let the cold gear oils stir on a short backroad cruise. Back in the driveway I smelled gas and immendiately shut it down. The rear carb was dumping gas out of the glass float chamber onto exhaust headers - hssss, hssss, hsss!. :shock: the front carb was dripping slowly as well. After cooling down, (and calming down), I started assessing the problem. Initially I considered the cold as probably shrinking the carb gaskets.
After disassembling rear carb I have other concern to share: The leaking carbs had both been freshened using my preferred stock of cork/composition glass bowl gaskets. The gasket had deteriorated to crumbs where exposed to fuel. I now assume the solvent nature of alcohol in current fuel was cause. I had an unused 'jiffy kit" hard composition gasket left over ,(I had sealing problems in past with this type on 1904's), and coated both sides with copper spray and installed / tested OK for leaks.
I just ordered two more "jiffy kits" for the hard composition gaskets but now concerned about related problems with all my old cars. I still have a stack of my cork/composition "preferred" 1904 bowl gaskets and will soak one in some modern gas to see if assumption is correct :hmmm: .
Have Fun (carefully)
8) that is one of the issues i have with most holley carbs, they run fuel through a gasketed area. and unless the gaskets were designed to deal with modern fuels, they will deteriorate much faster.
I've read that if the bowl dries out, the gasket also goes. It's definitely a weak spot for some of the Holley designs. I haven't been religious about starting up every couple weeks, but no gasket leaks yet on my 1904. It has a metal cover.
John/Fresno
Ya, mine were a constant source of leaks. I had a tri-power with a 1960 in the center and 1904's outers. Beautiful works of art, but I rarely drove with the hood up. Not only the leaks from new gasoline, but the float levels had to be set by trial and error. Always a problem, but if I were to do it again, glass bowls would be my choice cause you can't beat the look!
