Coating only the outside can also cause another problem: Mild steel tubing fatigues when it gets too hot. An outer-only thermal barrier blocks the heat from radiating through the exterior metal surface, while the lack of an inner barrier exposes the metal to added “trapped†heat. In a scenario reminiscent of that caused by the dreaded “curse of the mummified headers†(outer cloth wraps used by some racers), the result can be literal disintegration of the mild-steel tubing.
