Being mostly technically challenged I am attempting to understand carb cfm ratings.
4v carbs are rated by the factory at 1.5 pressure drop. Is there a definitive relationship/point between this and manifold vacuum? For example, when cruising down the freeway and the vacuum guage is showing 15 hg, at what point, if any, will the guage read when a 1.5 pressure drop has occured when applying pressure on the throttle and manifold vacuum drops...even pegging the guage at zero momentarily at WOT and slow speeds?
I have been through Vizard's discussion of pressure drop v cfm a number of times but somewhere I think am missing something or trying to read something into it that isn't there?
