I've got the 9" clutch disc setup, I believe from a 1967 model, and a 1967 flywheel (are there p/n stamped on these?).
I wore out the clutch, and bought a new clutch kit from M-pact through Rockauto. The pressure plate and the throwout fit fine. The clutch disc is the right diameter and the correct spline size, but the "hub" part of the disk interferes with the flywheel surface. It's too big in diameter for the recess in the flywheel. Is my flywheel wrong, or is this the wrong clutch disc?
Thanks,
Kevin
Thanks,
Kevin
