I would like to hear opinions on the best way to achieve the desired compression ratio. Is it best to zero deck the block and then set the combustion chamber size by surfacing the head or use some combination of non-zero decking the block and surfacing the head?
I am building a 200 cid with:
264/264 108 deg. cam.
Block bored .060"
32/36 Weber
DUI distributor
Want to achieve around 9.5:1 CR.
Block bored .060"
32/36 Weber
DUI distributor
