I just did a dry compression test on my 200 (did not have time to do a wet test). It has approximately 2000-2500 miles on it, and I was concerned something might be wrong since I can't get things tuned right wth the carb and timing.
Figures seem kind of low- 142, 147, 145, 134, 135, and 140 from the front of the engine back. By contrast, my worn 170 was 135, 140, 158, 155, 160, and 148 last time I checked.
The 170 in my old '63 comet that had been rebuilt but was well broken in checked in at 155, 160, 162, 155, 153, and 154. Does compression go up as the rings seal? I can see there are still hone marks on the cylinder walls- does this mean the engine is not fully "broken in" yet? Should I be concerned? I'm a bit worried that my lean condition (white-ish plug tips) caused my the continual carb problems I'm having could be doing harm as far as internal wear and/or sealing is concerned. Comments?
I'm still trying to work out the carb situation as I'm on my 3rd reman. carb and they are all worthless. I have no core to rebuild, so I'm about ready to take the jump and buy one from Pony Carbs.
Thanks,
Thor
Thanks,
Thor
