dawnovsky
Hi,
while still trying to address issue i ve met with my engine built, i have notice water (coolant) coming out the exhaust today.
I think this is a common sign of leak related to cylinder #1 passenger side head bolt.
I have used red RTV on tread, but it might not be enought.
Plug don't show sign of moisture, and there's no white smoke on the exhaust just droplet coming out the muffler.
Engine was hot and had run for 20 minutes before.
first idea is to remove the famous Cyl#1 head bolt, trully clean it and reinstall with proper amount of sealant . (Red RTV or blue stuff, don't know witch one is better)
gasket is composite type from CI and is new
i hope i will not have to remove head again to install new head gasket
thanks for advice.
thanks for advice.
