Originally my coolant temp sensor was threadedinto a T that came off the block. Clearly done by PO. I was unsure about whether totry to remove the T as it is soft brass.
My temp gage always seemed to work real slowly and lag badly based on engine temp at the radiator hoses as tested with a pyrometer.
So I took the sensor and put it on the part the radiator hose goes into at the front of the block.
Should I put a second gage in the back again? Or is directly in the collant stream okay as it is? If it overheats will this work correclty to show me the overtemp?
Cheers,
Steve-O
Pic is of new location for temp sensor.
Cheers,
Steve-O
