Crank, No start, Sitting for 5 years
Asa
2K+
So, I towed Susie down to Tampa last weekend
Dug through to find out why she wasn't starting, got that sorted. However now I have no spark so it's time to dig through that and see what's up.
Currently running a Duraspark II distributor controlled by a GM HEI ignition control module
I don't think the coil should be showing power on both sides, but it's been a while since I've worked on a gas engine, last thing I troubleshot was a 7.3L International Diesel, before that it was an '06 Powerstroke.
Here's what I am seeing.
KOEO:
Solenoid,
I - 12V
HEI Module,
W - 1.2V
G - 1.2V
B - 12V
C - 12V
Coil
+ 12V
- 12V
Dizzy
Purple - G of HEI
Black/white - Grounded
Orange - W of HEI
Asa":10kb4fyw said:
I don't think the coil should be showing power on both sides...
It had better show power on both sides; otherwise, the primary winding is open. This is with the breaker points open, of course. With the points closed, that side is at ground potential.
Joe
So, with an electronic ignition system like the DS2, is there an actual connection between positive and ground? Should I still see power there?
I would first swap in another battery. In working on many GM HEI's in the past have found that as little as 1/2 volt (lower) can cause a no start.
Wahooo, kool picks of my favourite non-runner!!! Too good for No 3 on http://kastang.tripod.com/fsp/parkinglot.html
http://kastang.tripod.com/fsp/68coupe200.html
But, No, your doing it all wrong.
First, kneal and pray that the Chevy part isn't the problem, and to be attentive to the issues it may raise.
Second, que http://www.sing365.com/music/lyric.nsf/ ... AA00228CF1
and sing "Wake-Up-Little-Susie" :party:
Third,
The HEI might be it. Since its the changed part, you'll need to check everything twice
Good fortune Evil 'Nana, this is most assuradley the most wonderfull post of 2012, and its soo good to see that sexy 68 being given the Asa magic. Props to you
Battery was fully charged when I started playing with it, battery discharged pretty decently over the half hour as I was testing and cranking and testing and cranking.
Besides, this particular HEI module and I have... a history. It should start with a battery that's a little low.
Edit: thanks X. It felt damned good to be hauling her down. Caught a good two dozen people craning their necks to look at her, one older lady riding passenger with her hubby in a Jeep Compass rolled down the window and gave me the biggest smile and a huge thumbs-up as they passed.
I smiled so much it hurt.
I think I have another HEI somewhere, but I doubt it.
Edit Edit: that's not my username or info... Susie's a '67 :?
:oopsie: Oh noooooooo1 I fell like the guy who found out Miss Universe was a, um, guy.
Nooooooooooo.
How did I get it so wrong :bang: :shockin: :splat:
I win Stupid Kiwi of 2012 Award :duh: :NZ:
Glad you getting it sorted, me, maybee some 65 dollar an hour pschatric help might be in order.
Gesh! :rolflmao:
I gotta laugh....
Asa":7ez71tqe said:
It is my Susie, but it's not my info
Ah, 68coupe200 from Pascagoula Mississippi, thanks.
I don't feel quite so bad, but I'm still realin' a fair bit. I need to write lines on the differences in 67 to 68 Stangs, eh? I never even thought.
Get back out into the garage, its 21:38 Thursday (EDT) - Time in Tampa, FL, USA
2:38 here in Moo Zealand
Breakerless ignitions simply use a solid state switch in place of the breaker points. As far as the coil is concerned, there is no difference whatsover. I will try to explain a bit, using breaker points as the example.
With power applied to the + side of the coil and the breaker points closed, current flows through the primary windings of the coil. This causes "electomagnetic lines of flux" to build up around the primary windings. Since the secondary windings are wrapped around in close proximity to the primary, these lines of flux also surround the secondary windings. At some point in time, these lines of flux get as big and strong as they can get at that particular applied voltage, and the coil is then said to be "saturated".
Now, we cause the breaker points to open, which stops the flow of current in the primary windings. The electromagnetic field can no longer be sustained, so it collapses. We know that moving a wire through a magnetic field causes an electrical current to be "induced" in the wire, and the same thing happens when we have a stationary wire (the coil windings) and a moving magnetic field (the collapsing lines of flux).
This collapsing electromagnetic field induces a current in the secondary windings, but since there are about 100 times as many windings in the secondary, there will be a whole bunch more voltage (and a whole bunch less current) in the secondary. One end of the secondary windings is attached to the spark plug (via the distributor cap) and the voltage builds up until it gets high enough to jump the spark plug gap. At this point, the voltage stops climbing, and pushes the current across the gap. It is the heat from the current that builds the fire, NOT the voltage. Voltage is needed to strike the arc, but once the current begins to flow across the gap(s) the voltage actually decreases.
Now we can close the points again and start the cycle all over. This all happens really fast.
This is, of course, Direct Current (DC) so all of the DC rules apply. With the points closed, the Negative side of the coil is at ground potential, so you will not read any voltage there. When they open, you will be able to measure 12 volts at the Negative terminal. I have used this many times to set the static timing on Volkswagens, just connect a test light to the Negative terminal and rotate the engine by hand until the points open; this will cause the test light to glow, indicating the points are open.
You can also test for spark by rotating the engine until the points are closed, energizing the coil, and manually opening the points. Be careful! This can be a shocking experience.
In theory, all of this applies to breakerless inductive ignitions (we won't talk about CDI today). If you just think of the module and pickup sensor as replacing the breaker points, it makes it easier to understand. I did over-simplify, and left a lot out, but I'm telling a story, not writing a thesis.
You can always test a coil just by jumpering power and ground to it, then removing the ground. It's best to connect a plug to ground as well, or the coil may discharge through you :shock:
Joe
