The first row is longitudinal, the second is across the bore.
--------top-middle-bottom
1-----3.682 3.681 3.684
-------3.687 3.677 3.687
2-----3.683 3.674 3.678
-------3.682 3.680 3.679
3-----3.682 3.679 3.679
-------3.682 3.679 3.679
4-----3.681 3.679 3.679
-------3.683 3.678 3.679
5-----3.679 3.677 3.679
-------3.683 3.679 3.677
6-----3.680 3.677 3.679
-------3.677 3.676 3.680
Do these measurements seem reasonable?
I haven't mic'ed a block before, so I guess accuracy is relative to experience and feel.
It is also a cold block with temps around freezing here.
So I need to decide if this block can just be honed and put back together.
The compression was very good before disassembly @ 166, 170, 174, 174 164 160.
I would like to spend as little as possible on this at the moment, so I'm hoping to use the old rings and pistons.
Whaddya think?
I want to have the machinist just hot tank, deck for flatness, hone, install cam bearings and cam.
I would like to reinstall the rotating assembly, if it can be reused without machine work.
Whaddya think?
