Well, I tried drilling out the the heat riser tubes, but the screws won't come out. So I think I'm going to give up and just pull the head back off and take it to get welded right. Should have done that first. If you don't know what my problem is...my port divider has come loose and is rattling up a storm.
here is my decision. the reason I'm hesitant about pulling the head, is that I had a thin head gasket on.
If I remove the head, I'm going to put roller tipped rockers on. Think the extra lift will give me some of the power I lose by dropping half a point on compression? I'll be at 9.0:1, which I guess I can at least run mid-grade vice high grade.
I love this car...I really do...
Slade
Slade
