Can anyone try to explain the difference b/w valves knocking and spark knock?
I've been hearing a knocking/rattling sound from the motor under load for the last couple of months.
I just installed a Pertronix ignition and replaced the plugs, roter and dis. cap. I readjusted the timing (it was soooo far off the scale!). It is now about 9 to 11 degrees BTDC and the knocking is much less. I'm just wondering if there is anything else I can do or am I due for a valve job?
Thanks,
Scott B.
Thanks,
Scott B.
