I was wondering if there is a difference between the stock lifters and lifters from a performance company like Isky. Also i had to pull engine back out of the car due to a tapping noise that i thought was coming from a rear lifter. But also thought maybe it might be that the cam lobe went flat. I pulled the rear lifters out and there was no ware on the bottoms to indicate the lifter was bad. Is there anything else i should check on the lifter to check if it is good? Should i be able to compress the center on the lifter cause i could not. Also am i able to tell if a cam lobe went flat by looking through the lifter hole or do i need to remove the cam? I am not sure what i am looking for on the cam lobe.
Thanks,
Nazs
Thanks,
Nazs
