i am in the process of putting a 1979 200 in a 1963 falcon. i have followed falcon performance handbook since the begining of this swap. my problem is when you take the oil pan from the 63 falcon the oil sump is in the front of the engine and the fairmont is in the back of the motor. so when you put the dip stick in it hits bottom of oil pan. if i put 5 qts of oil in the motor and then modify the dip stick will enough oil be in that area to read on the stick. if not what do i do thanx. cocacolaman
