8)
1) Did the Oz heads come with valve seats? mine has machined in valve seats. And I thought someone said the Oz heads were 1.65" intake and IIRC 1.39" exhaust. Mine has 1.73" intake and 1.49". If I can sell some Stang parts this weekend I am going to try and get some one piece stainless valves with the back cut heads.
2) Is it normal for the exhaust valves to be non magnetic? The intakes I can pick up with a magnet but the exhaust valves are non magnetic.
3) Whoever previously owned my intake ported the intake runners to slightly past the intake gaskets.
4) Can someone post some pics of a ported SB inline six exhaust port. Im kinda studying them as their doesnt seem like there is alot I can do as far as straightening or opening it up. I am open to suggestions from the experts om tips and suggestions. I am also suprised at how smooth and clean the castings in the exhaust ports are.
5) The intakes Im just going to clean up and smooth some edges and transitions but they look very good to begin with. No hogging out as that will kill low end velocity. Not trying to build a 7000rpm drag motor.
This motor is going to be redlined at 6000rpm but I will probably limit it to 5000-5500rms. Looking at a cam around 264-272deg dur and about .450" lift. Compression is estimated to be about 10:1 when done but I still have to cc the chambers before I clean them up and unshroud the valves.
My goal is to pick up about 20hp or more over a stock Oz head. I feel most of this will be picked up in the exhaust and by unshrouding the valves.
Any advice will be appreciated. Thanks.
