The goal is two lights on the Christmas tree, man!
I'd forget about pulling more revs to get more power. Everyone looks at trying to punch through the Rev barrier, thinking power is rpm times some factor of torque. Power is brake mean effective pressure, and running any thing that improves PLAN will gain power.
PLAN to make power!
P is Pressure, BEMP
L is length of stroke
A is Area of the piston
N is the number of cycles, rpm
Always, always look at The P first!. Efficiency by reduced friction, better head flow, thighter tollerances (can you deck the block or run a 22 thou head gasket or a less tha 5.5 cc piston or reduced the ring tension flutter and control crankcase pressure or vent it)
Basic calcs show 5200 rpm is 85 mph at the end of the trap.
Since you are going to have to make it quicker, you'll have to work go righ to a taller diff. Then experiment with legal mods which allow the car to produce more power. Check on the data at which Fords bigger log intkae cae out on the Maverick. Find the maximum legal size of the carb venturi and the actual head casting number you have to use. Without doubt, I'd be looking at the later log manifold used on 250's since 1970, and 200's since 1972, if its legal.
Are the rockers within the normal production tollerances? There might be a few thou lift on a set of 1.53:1 stock factory lifters. The Rhoads lifters are desined to run as solid at full rpm, but I'd look at stock lifters which Lunati might recomend, and then find the lightest spring you can use to avoid valve float at 5200 rpm. If you gear up the car, and make it work harder withion the rules, then you can gain power by using a weaker spring that isn't seeing more than 5200 rpm. Big suspension springs don't again power, they just allow an engineer to sleep at night.
The plugs need to be indexed, if a scatter pattern cam can be used, there is heaps more power to be had. Is your engine a four bearing 200? I read somewhere that it wasn't until 1973 that Mavericls ran the 5 hp more 200 seven bearing engine. The four bearing crank and block will have less drag on it, and be just that much quicker than one without another 3 bearings sapping power.
The stall ratio could be changed to 2350 rpm within the rules.
If you could find a set of 4.4:1 gears, and cencentrate of optimising what happens below 5200 rpm, that's where the time savings are.
Can you soften the shocks and reduce the front sway bar to improve weight transfer? Can you firm up the transmission shifts by running a better servo piston or more aggressive shift kit?
