Tighthead123
Active member
Hello,
Drum brakes 65 Mustang.
Drum was in good condition
Replaced shoes and all hardware, springs, adjuster, cable guide, and wheel cylinder.
Shop Diagram shows a “shoe retracting assist spring” There was no such spring installed when I took it apart. Do I need this spring?
AutoParts store said I didn’t need it.
My issue is that the secondary shoe keeps coming off the anchor pin.
I have correct pads. Measured drum and pads to make sure. Plate that pads sit against is smooth.
maybe a faulty wheel cylinder? Wrong springs? I adjusted till drum dragged then backed off a little. Any suggestions? When I get my Jack back and can take wheel off I will send pics.
Thanks!
Thanks!
