Dual exhaust W/ Pacemakers in... Well sort of
bigcatchdaniel555
I got the pacemaker long tube duals from Mike and i got the summit system for a 289 dual exhaust with turbos. I have the front fabbed to fit the same side exit of the headers I also have the tail pipes ready to hang bu i can figure out the mufflers summit sends me some l rubber brackets shown on their site here:
http://store.summitracing.com/partdetai ... toview=sku
but i cant figure how the mount from the mufflers to the floor boards the mufflers have no end tabs on them for bolt and the directions simply say secure the rubber end to the bracket via clamp but there is no place for a clamp except directly to the outlet pipe which makes the clamp too short any advice.
They expect you to hook that thing under your u-bolt. If you think the bolts will be too short, you may need to spring for 2 larger ones. Use their supplied ones to seal up the exhaust tubing to the muffler and use 2 generic ones to hold onto the strap/hook.
-ron
thanks coupe boy. I got the hanger figured out so both mufflers are mounted and so are the tail pipes hopefully the header will come in the mail tomarrow and i can get it running and post some pics.
Finally got around to instaling everythinh like the sound of the dual turbo over the single flow 40 a lot take a listen look t the pics tell me what ya think.
The idle was a bit high i bumped the adjustment screw putting in the header i put it next to my friends 289 with duals he had flows but its a little too loud for me the deep rumble on both was imiliar I like it. :twisted:
