fxp
You may remember I did a dyno run when I installed the headers, that showed some handy gains. http://fordsix.com/forum/viewtopic.php?t=39873
Well the next stage was installation of the DUI. Essentially the car is unchanged from the header runs, bar the dizzy. The run sheet is here below.
There's good news and bad news, that might need someone with a bit more knowledge to interpret. So I'll give you the bad news first. The peak HP LOST 2.3HP! Huh? Three runs in D and all the same result. Talking with the guy, the theory is that the stock carb just can't deliver the fuel. The results showed a lot leaner burn which you would expect.
Anyway like I said there is good and bad news. The loss at peak HP was in Drive. Everywhere else the results are startling. In Low the peak HP moved up from 41.4 to 51.5! (ie up more than 24%). The power comes on way earlier as you can see and gives a much flatter curve. There is more power than the old peak from before the original curve even showed up all the way past the original peak. Torque in low is insane. Up from originally measured 410 ft-lb to a peak of around 700 ft-lb! (70%). Again comes in much earlier and the curve is never below the original peak.
In D the torque is again improved with the peak going from about 315 ft-lb to 370 (17% gain). Again coming in much much earlier. The power curve in D isn't all bad news either. As with all the other results the curve comes in much earlier and flatter. It's making power through a much wider rev range.
As I said, on first look it would seem that the carb can't deliver the fuel, although seeing as the engine's doing the same revs in L as in D (just slower speed) maybe that ain't it at all. I'd be interested in the analysis of a few other more experienced operators.
Anyway that's the numbers. On the qualitative measurements you can feel the extra power and torque low down. The idle is smoothed right out. I can now set the idle down to 600, whereas with the points even at 750rpm it was rough. The next step for me is a weber carb, so I'm hoping that will help richen up the mixture and get more of the benefit of the DUI.
