SoCar72
Having a '63 170 with the 1/4" shaft Load-o-Matic Distributor, I'm interested in options. Ultimately, I'm trying to get away from the LoM distro and Spark Control Valve system for greater carb and distro options and tunability.
CI offers a DUI unit for my application. It's a little pricier than I'd prefer, especially considering that I haven't made up my mind on whether, when the time comes, I will rebuild the original block or swap it for a later 7 main 170 or 200. The later block has a different size distributor bore, hence the distro will not transfer. Does anyone know if this distro can be adapted from an earlier block to a later one?
Is it possible to retro fit a LoM (SCV vacuum only advance) distro with a mechanical / standard vacuum advance system?
Is there a standard m/v advance distro available for the early 4 mains?
Is it possible to adapt a later single point distro to an earlier block?
Or is there another option I am not aware of?
