Is there an easy way to tell if a C4 is early or late? (I seem to remember something about number of oil pan bolts?) Also what years would be considered "early"?
Look for a "build tag" on the servo cover, that'll solve all questions.
There are many filter designs. Sometimes you can get close by comparing filter shapes.
What year are you looking for? There are 24 and 26 spline input shafts. If your torque converter has to match your engine, make sure you get a trans with the correct input shaft.
