Ebay Turbo Maps
I want to use a Ebay Turbo but have no clue how to get the maps for the turbos that are for sale... any Ideas?
I found this one on turbobygarret.com, that works perfectly my line up ends up almost PERFECT on the dotted line. Except it says for engines 400-600 hp, which i doubt my car will be putting out.
After doing ALOT of research this is what I found. Can anyone second check this? I followed there example so where I didn't know info I followed theirs. So I don't know about VE and stuff.
Wa = HP * A/F * BSFC/60
Where:
· Wa = Airflowactual (lb/min)
· HP = Horsepower Target (flywheel)
· A/F = Air/Fuel Ratio
· BSFC= Brake Specific Fuel Consumption (lb/hp*hr ) ÷ 60 (to convert from hours to minutes)
Wa = 300 * 12 * .57/60
Wa = 34.2
MAPreq = Wa * R * (460 + Tm)
VE * N/2 * Vd
Where:
· MAPreq = Manifold Absolute Pressure (psia) required to meet the horsepower target
· Wa = Airflowactual(lb/min)
· R = Gas Constant = 639.6
· Tm = Intake Manifold Temperature (degrees F)
· VE = Volumetric Efficiency
· N = Engine speed (RPM)
· Vd = engine displacement (Cubic Inches, convert from liters to CI by multiplying by 61.02, ex. 2.0 liters * 61.02 = 122 CI)
MAP = 34.2 * 639.6 * (460 + 140)
.89 * 5500/2 * 200
MAP = 13124592
489500
MAP = 26.8122
P2c = MAP + ΔPloss
Where:
· P2c = Compressor Discharge Pressure (psia)
· MAP = Manifold Absolute Pressure (psia)
· ΔPloss = Pressure Loss Between the Compressor and the Manifold (psi)
P2 = 26.8122 + 2
P2 = 28.8122
P1c = Pamb - ΔPloss
Where:
· P1c = Compressor Inlet Pressure (psia)
· Pamb = Ambient Air pressure (psia)
· ΔPloss = Pressure Loss due to Air Filter/Piping (psi)
P1 = 14.7 – 1
P1 = 13.7
Pr = P2c/ P1c
Pr= 28.8122/13.7
Pr= 2.103
According to my best calculations thats what I got ... jeez that was confusing enough then I get to search maps =(.
That turbo would be way to big for a 200. Check out www.turbofast.com.au you can use the turbo calculator programs to get some idea of the size you need. One of the smaller GT25's would probably be what your looking for.
Find out what "compressor trim" the seller's turbo is.
Without that info, I would NOT buy it.
