Just curious about possible side effects of a hotter cam.
As you may or may not know, I'm running a Comp Cam 260H cam. fairly mild, but it doesn't shift the power curve a little bit.
With this shift, should my idle vacuum be lower then normal? I can't really get it above 18" Hg, but that is at about 18 *BTDC.
Also, should my gas mileage suffer ( used to be at 25 MPG on the highway, not I'm like 18 MPG on the highway, with a T5)?
Right now I'm running at 14* BTDC. According to Comp Cam the cam runs advanced of 4* BTDC, so is my engine running at 18*BTDC even though I'm set a 14* BTDC?
I guess I can retard my timing some more again and get back down to 8* BTDC, but then my vacuum is around 14" HG. So basically, is that normal for a hotter cam?
Slade
Slade
