SR_Crewchief
I'm sure that this has been discussed to death at some point...but my searches over the last few months on several forums haven't turn them up.
I know that I'm going to over simplify this, but that's do to my not having enough technical background on the subject so please bare with me.
I can understand why just increasing the TB size will gain no net hp/tq gains. Among other issues the air volume delivered exceeds what the EEC is expecting for a given throttle position. Potentially creating a lean condition if the programing can correct for based on O2 sensor feedback.
And I can understand why just increasing injector size also has no net gains as well. Delivering more fuel than the EEC expects for a given duty cycle. Potentially leading to a rich condition....
I presume that it's not practical to increase injector size proportial to throttle body increase without needing to alter control tables to keep a/r in acceptable ranges. Effectively what is done when you swap to a larger carberator. My assumption is that the current combination of twin 47mm(in think) throttle body and 14# injectors are at or near optimal for what the current head can handle, short of forced induction. At least with the stock cam.
I'm currious as to whether a mildly ported head, longer duration cam(240-250 duration range), improved exhaust ( for sake of arguement 3" single pipe behind long tube headers), twin 61mm throttle body and a proportional injector set (19# ?) could be in range of what the stock programming could comensate for. Speed density not MAF.
I've got to be overlooking something obvious, but just don't have the fuel injection foundation knowledge to see.
