Electric Fuel Pump for Carbed applications?
Broncomike
Active member
I believe the cam eccentric on my 300 is worn, as I'm having issues with fuel supply and think it's part of my truck running lean. New mechanical pump didn't help.
Since I'm prepping to swap an efi block, I'm looking at electric pumps, regulators, etc.
Any suggestions on pump and regulator selection and whether I should run a return line? Can I run a T to my existing line or is there spot to run one on the factory 1985 tank?
I've been looking at a couple of Carter inline pumps in the 4psi range but gph seem low at 15gpm versus a 5-9psi pump at 30ish gph.
sdiesel
1K+
I trust the facet- Purolator pumps .
They have exactly what you need. In terms of pressure and volume. And they are a lift pump as well as a pusher.
Great pumps
Return lines. Does ur 85 have just 1 tank? If regulated there is no need for a return line but regulators do offer that option.
My fish carbs require a Max of 3 pounds , any more and they burble like an unhappy child.
I don't use a return line. A fuel pressure gauge at regulator is a help .
DoctorC
Supporter 2020
Supporter 2019
Supporter 2021
Before you make this jump read a little about electric pump drone. I had this as part of the carb upgrade kit and was all prepped and ready to go. But when I was trying to read about the best pump fixation location / method I came across tons of people who uninstalled these afterwards because the constant drone they produce. So I chickened out.
Turns out modern cars isolate the pumps from the frame to avoid this. Very hard to do in our oldies.
But, if that keeps you from a cam swap it might be worth it.
THE FRENCHTOWN FLYER
5K+
Supporter 2021
Supporter 2020
Supporter 2018
At a BSFC of .50 (typical WOT) 30 gph will support about 378 hp.
I use one of those cheapie Carter pumps on my 5.0 HO powered tub with good results. (but I do keep a spare handy). They are noisy though.
A Holley red internally regulated is also an alternative
https://www.speedwaymotors.com/Holley-7 ... 91EALw_wcB
Broncomike
Active member
I was looking at something like this https://www.amazon.com/Carter-P90091-El ... 589&sr=8-1
I think one application is an early 80s carbed S10 with the 1.9l. The problem is they're rated 2.5-7 psi and I'm worried that 2.5 on the low end isn't enough? That style pump.is supposed to be pretty quiet and a factory application seems easier to find at a parts store. They're supposed to be quiet as well.
I saw those Facet pumps, wasn't sure on the quality so thanks for that, I'll check them out as well.
It's a Bronco so just one tank, my only concern with a return line was, I've heard vapor lock can be an issue without one but no personal experience with it.
5K+
Supporter 2021
Supporter 2020
Supporter 2018
I had to put a fuel return line on my 460-powereed '46 pickup and eliminated 90% of the hot fuel handling issues.
Since I welded a fitting into the filler pipe it was a relatively simple process.
sdiesel
1K+
Facet - top o the line stuff, we use them in const as lift pumps they last forever and can pull 10 feet easily diesel or gas, and in one case, water.
I buy the type with the spin on strainer.
