Pete W":282223ph said:
Woops! The car is a 1961 Comet with a 144 and a 2.77 three on the tree.
This might be a good time to consider a swap to either a 200 or perhaps even a 250 if that would fit and if you don't mind spending a small fortune to complete the swap. Yeah, either would require a bit of work (to say the least), but it might wind up being a good choice anyway.
And while you are at it, perhaps a transmission swap might be timely, too, eh?
On the other hand if you have been happy with the 144 and the 3 speed manual, you may just want to rebuild the 144. If the main or rod bearings are going, there's likely to be some nasty crud in the oil which might work its way into cam bearings and other parts of the engine so it's probably a good time to give the thing a complete overhaul with all new bearings, a new cam, new lifters, new seals, and all that sort of thing. In effect you'd be replacing or renewing any parts that are prone to wear with the possible exception of the pistons. If, however, the cylinders are scored (and unless that portion of the engine has been recently renewed they probably are) then a mild overbore and new pistons might be in order.
Then again, if you are going to do that much work, maybe a swap to a remanufactured 170 or 200 short block of more or less the correct vintage might be the better choice. Pay attention to bell housing bolt patterns unless you can get a new bell housing or transmission to fit the new engine at a price you're willing to pay.
