I'm hoping to get the 144 stabbed back into my '63 Falcon this weekend and I need some help with the engine hardware. I ordered the kit from Melvin's but it doesn't look like it'll be here in time.
I'm looking for the lengths of:
-Water pump bolts
-Water neck bolts
-Timing cover bolts
-Oil pan bolts
-Fuel pump bolts
-Exhaust manifold bolts
-Generator bracket bolts
-Coil bracket
-Valve cover
-Fan (no spacer)
-Oil pump to block
-Dist. hold down
Any help would be much appreciated. Thanks
-Water pump bolts
-Water neck bolts
-Timing cover bolts
-Oil pan bolts
-Fuel pump bolts
-Coil bracket
-Valve cover
-Fan (no spacer)
-Oil pump to block
-Dist. hold down
