Make sure everything is in top contition and state of tune. I have heard that sometimes something like opening the hood to the safety catch will let enough air flow to keep things cool, you just have to remember to do it and latch it again before you take off. Some people have luck with an electric fuel pumps. In my 73 cadillac I installed an electric fan on a mechanical timer. I wind it up to about 15 minutes when I shut it down. For the most part it does the trick. If I seek out non oxy fuel its not nearly as bad so Im fairly sure thats my problem, its just too much work to try and need gas when Im near those stations plus non oxy is only available in preimum which my car does not need.
Maybe someone else will have some better tips or other things to check.
Good Luck and keep us posted if you figure it out.
