Exhaust manifolds
81slantnosewp
stock log type
Heavy Duty
rare ak miller turbo manifold discontinued
Hedman Street Headers 89300 (painted)
Hedman Street Headers 89306 (Ceramic coated)likely looks like above image with different coating
Hooker Super Competition Headers 6823HKR
clifford truck headers
protuninglab headers look like hedmans with chrome
not much information except the seller was eugene discontinued 6into1
its been confirmed clifford had a set of shorty headers at one time
stock fuel injected manifolds if im not mistaken there are 2 or 3 different castings that can cause clearance issues with some carb intakes but nothing major
more information on mounting EFI manifolds on older heads
https://fordsix.com/viewtopic.php?f=2&t=78974&p=609538&hilit=FI+clips+Clifford+alignment
Marine dual intake and exhaust manifold water cooled
{all images have been save to ford six gallery}
BigBlue94
1K+
Supporter 2021
Supporter 2019
The Clifford truck headers fit well on an 85 bronco. They have 1.625" primaries and 2.5" collectors.
old28racer
1K+
With my 1971 F250 4.9L inline 6 motor I am trying to keep a more stock cast iron engine compartment look, so I will be removing my existing headers and running a pair of EFI cast exhaust manifolds. Also I really don't care for the header/starter problem. I will be running a hogged out 240 cast intake, 2x2 aluminum adapter, my current Holley 2300 2bbl carb. Think it will make a nice looking engine setup with a bit more performance.
BigBlue94
1K+
Supporter 2021
Supporter 2019
I'll add pics to supplement my previous post.
Clifford truck headers, after 15 years.
After a treatment of Jet-hot 2000° offroad coating.
Close up of the Jet-hot, though I cant remember which color; cast iron or titanium.
Mated up with a Clifford intake, painted Ford Gray. Colors match perfectly.
And the shape of the y-pipe for said headers. Custom made with mandrel bends and the flowmaster scavenger y-collector.
Capjack01
thanks for the clifford pics. thats the first shot Ive been able to find that showed them installed.
a couple of the primary concerns about running headers is starter heat soak/entrapment. from the earlier pics they seem to be routed slightly different from the hedman and hooker sets. does it help at all with trapping the starter or is it still a case of pulling them off to do a starter change?
BigBlue94
1K+
Supporter 2021
Supporter 2019
It is possible to get to the starter IIRC, but not very easy. It's been running the same large case ford starter for years with no issues. Even in moab when the engine was at 240° from the headers heatsoak, the starter had no issues.
81slantnosewp
from my experience efi manifolds already mount onto the older heads the difference is in the ease of installation the newer heads had studs to aid in the process but were not essential to function whenever I have put efi manifolds onto an older engine the engine was outside of the vehicle it might take some fiddling, a couple of headaches, and maybe a second set of hands but not impossible
guhfluh
pmuller9":2wcnnhx5 said:
Protuninglab stainless header.
https://www.protuninglab.com/hds-fpu65-2wd-lt.html
[image]https://s.yimg.com/aah/yhst-11161747262114/75-89-ford-f150-f250-3-9l-4-9l-rwd-stainless-exhaust-manifold-header-replacement-1.jpg[/image]
"Protuninglab" may be one of the more reputable vendors, I don't know, but there are many other vendors of the same Chinese made stainless header on ebay. DNA Motoring is one I'm probably most familiar with(and it's cheaper). https://www.amazon.com/dp/B07RD5D9XZ/re ... wEbYJZDQFH
BigBlue94
1K+
Supporter 2021
Supporter 2019
While reinstalling my Clifford headers yesterday, I took a gander at the starter. I'm pretty sure theres no way to get it out without removing the headers, or at least one. Unbolting it is possible, but theres no room to remove it.
Firepower354
1986F150six":1fp8iv05 said:
I just ran across this and thought of this thread [as well as the intake manifold thread].
https://www.ebay.com/itm/ECON-O-POWER-M ... SwX-Zd3rZc
I've been watching that but it's about 4x more than I could justify. Adding a couple more 1v carbs, and Jet Hot coating the inside of both cavities, has been in my mind for a decade, on the brand C cheap ones(even aluminum ones!). The absurdly ancient design of the multi piece manifolding and washers is sorta effective, but still my least favorite part of inlines.
pmuller9
5K+
Supporter 2018
Supporter 2021
see post #21 in the "Intake Manifolds" thread.
Firepower354
Yep, but that only addresses the "easy" part of what the uni-log fixes. I dig the solid single flange and one-piece-ed-ness :)
I have a HD exhaust mani on now, and an EFI lower on the bench with a 2v intake, and a pile of bends, that I may try. No heat makes that seem a bad idea though. My van is tight for a fab-A-log out that far.
[image]https://fordsix.com/img/_data/i/upload/2019/03/17/20190317202526-22dc17a7-me.jpg[/image]
sqrbckguy38
So I've been hearing at great lengths that these headers will not fit a 4WD truck. Is there a specific one that will, or are they all interference fit? I ask for my 79 cause it could really use a nice exhaust and intake upgrade. The Highboy we have sorta kicks my poor little guys ass in acceleration, and anything else.
BigBlue94
1K+
Supporter 2021
Supporter 2019
I have Clifford headers on my 85 bronco. No issues at all. EFI manifolds would be better though, as they are less hassle. And they keep heat in better. But longtubes really sound good on 300s. Mine join into a single 3" high flow exhaust.
68Flareside240
Supporter 2021
Supporter 2020
Supporter 2019
Not a new design, but Hedman is now offering their 89300 header in a Black Maxx ceramic coating, part #89303.
