78 granada
Always wondered how soon after an initial priming with a drill is best for starting..immediately? Its going to take a minute to get the distributor in and all set. Once the oil drains down anyway, is it ok to wait a day or so? Also, with the RAU adjustables I have in, the adjuster is going to be jumping around!! I hear talk of adjustment while running. Here I go obsessing again!!!! Just want it perfect. I have the timing mark rough at 10 degrees so with the rotor pointed at #1 should be good for starters. Any advice from you veterans? Oh yea, I don't find a ballast resistor on this 78 Granada 250. Would you run the old hot wire to the new DUI single wire setup? Thanks guys.
