As Rich said, cast pistons such as sealed power for a tempo engine being a flat top piston will be fine.
However the piston pin is offset .090" which will enhance low end torque.
The plus of a custom forged piston you can center the wristpin which will enhance midrange & highend power.
You can also offset the wristpin .030"-.060" to the non thrust side rather than the major thrust side. Result more for top end power.
thats the pros & cons. Bill
