I found a DODE head at a local shop and they want $150 for it (as is). It was previously rebuilt by them (several years ago) and has been just sitting on the shelf collecting dust. It has the larger 1.75" carb hole, ~1.7" inlet and ~1.4" exhaust valves. It does not have the hardened seats. It has a three angle valve job.
Is the hardened seats worth the extra expense? The owner said he would reperform the 3 angle valve job and add the hardened seats for an additional $218. That would take the total to $368. Good deal?
He would also cc one of the chambers to see if the deck needs milling or not (I told him about the cc / head gasket thickness and killing the compression ratio that I've learned about from this forum). Milling the deck would be an additional $48.
The casting number shows up on Mustang Geezer's website under the 170 engines, so hopefully it is a 52 cc head?
The two questions (o.k. three):
Is it a good deal?
Is the extra $218 worth it for the hardened seats?
What carbs will fit the 1.75" hole?
ski
Is it a good deal?
ski
