FSPP roller rockers causing headache please help
Mustang Boy
i just put on the FSPP roller rockers and i am in the dark about how to adjust them if anybody could help with exactly how to adjust them for peak performance i would be very gratefull.
i need help i will be very grateful for the help and wisdom i will recieve!
Disconnect the coil wire first for safety, making sure the motor won't accidentally start. Some guys prefer to remove all the plugs too, so that the engine is easier to rotate during the procedure. Make sure to mark your plug wires before disconecting, so you don't mix up the firing order when reinstalling them.
Next rotate the engine until the number one (#1) cylinder is on TDC just after the compression stroke (you can feel the compressed air by putting your finger over the spark plug hole).
Now you can adjust the following valves:
#1 intake - #1 exhaust - #2 intake - #3 exhaust - #4 intake - #5 exhaust
Next, rotate the engine until the number six (#6) cylinder is on TDC just after its compression stroke (one full revolution of the crank shaft). Now adjust the remainder of the valves:
#2 exhaust - #3 intake - #4 exhaust - #5 intake - #6 intake - #6 exhaust
Adjust the valves by backing off the adjuster so that the pushrod can be easily rotated between your thumb and forefinger. Then slowly tighten the adjuster until you can no longer rotate the pushrod. Tighten the adjuster an additional ¼ turn, for the proper preload on the hydraulic lifter.
Note: The valve adjustments should be done on an engine that has been warmed up. Make sure to let it cool off sufficiently so that you don't burn your fingers while rotating the pushrods. It is also a good idea to place a drop cloth or oil pan under the car/engine to prevent oil drips on the floor.
Right from your website, right Mike? :wink:
Are you setting up the full rollers? If so, one thing I'd like to add...
When installing them, make sure the adjusters are backed out all the way. If now, when you torque down the allen head cap screws that hold the rocker assemblies to the riser, instead of torquing agains the riser, you may be torquing against the head of the push rod itself...ungood. Don't ask me how I know :oops:
I'm still fighting with my Yella Terra full rollers a bit as well, but I don't know (don't think) it's a problem with them as much as it is user error or other issues...still looking into it all.
Let me know how you do with yours. What is the rest of your motor build up like?
I am doing all of package D from FSPP and engine is out of car right now been out for car for about 2 weeks while doing a full rebuild engine goes back in car tommorrow so i can start it up before i have to go back to school Monday
