Ever since I installed my new rearend & gears it takes off hella fast but starts to lay down in 3rd gear.....it doesnt spit or sputter but just seems to lose power
Well I ordered some new parts from Summit and installed them and I have a fuel pressure problem it seems....
Heres a pic of the new fuel lines, filter & gauge,
And here is a pic of the fuel pressure gauge,
Anyone see the problem?
I start out with 5 psi of fuel pressure and after it runs for 4 or 5 minutes the fuel pressure starts dropping.
It'll drop down to 2.5 psi after 10 minutes or so....obviously this is a problem being the Holley needs 5-7 psi to work properly.
Any reason why my fuel pump should start to lose pressure after it warms up?
Its not a tank/sender unit, filter, line problem.
I'll just install a electric fuel pump on it but I was just curious if anyone would no why it would drop pressure like this. Usually in my experience, they will rupture a diapraghm and spew gas in the oil pan.
Anyone have a part number for a inexpensive electric fuel pump like a AC or Carter pump? I would like a Holley fuel pump but cant afford the $125+ price tag right now.....was looking for somthing in the $45-$55 price range.....?????
Thanks,
Doug
Thanks,
Doug
