Seeing as I am At wits end with my carb issues, I remembered reading that Weber carbs like lower fuel pressure...around 3-4 pounds.
I know I am grabbing at straws here, but Holly makes a variable fuel pressure regulator that goes from 1 to 4 pounds. Here is the link http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=1463&prmenbr=361
Since our fuel line is a 5/16" preformed line. How would I go about installing this? Would I just change the preformed line to a rubber line? The regulator uses 3/8" NPT fittings.
