Greetings guys,
When asking questions about my head rebuild & a few associated problems I had in the initial stages, several people advised on using washers with the head bolts if the head had been resurfaced to prevent the bolts from bottoming out. Wondering if this is a possible point of concern & feeling that Ford would not likely use a bolt the same length as the hole depth, I did some measuring.
The experiment:
Performed on a 170. With the head gasket & head on, I measured the hole depth. Then, I measured the bolt length. (Whew! this scientific stuff is time consuming;-)
The findings:
The head bolts were an average of 1/2" shorter than the holes. The obvious exceptions being the 2 that have no bottom because they hit the water channels.
Conclusion:
Unless you remove more than 1/2" from your head, you probably don't need washers. I would imagine a 144 & a 200 would have the same results.
Disclaimer:
Always measure before skipping washers. The previous owner may have replaced the bolts with something slightly longer at some point.
Hope this saves somebody a trip to the hardware store looking for 7/16" washers. Most places don't have them. Napa does.
Happy trails,
David K
63 Comet
seattle
The experiment:
The findings:
Conclusion:
Disclaimer:
Happy trails,
David K
63 Comet
seattle
