simon
got myself a used set of adjustable rocker arms, supposedly in good condition.
Bought unseen, and much to my dismay, they're all worn a good .010-.016 at the tip. wear clearly was caused by a lack of lubrication.
generally, replacing worn rockers is considered the better way of dealing with such problems, yet new rockers are somewhat hard to come by in this part of the world.
So I'm thinking about saving the ones I have, grinding the tips, shot peening and maybe carburizing.
The chebby-wrenching 'nam vet in our shop and his fellow who worked for Lycoming in the 70s said it'll never work, since it'll change geometry completely.
On the other hand, oldschool hot rod buddy with an '38 ford sedan and even more experience than the Lycoming guy says as long as they're kept in their place with their corresponding valve and pushrod, it'll work out ok for a stock rebuild.
In case I wanted to grind, he suggested to check valvetip and keeper clearances real good. He also recommended backcut valves especially with decreased rocker arm ratio.
what's your opinion?
