go to state title go out kill them in the first heat but brake the rings in the 2v doing try next heat getting worse park it.
fair enough it sat for 10 years then had its ring driven out for 5 race meetings this year.
had built over xmas for next season a xflow all the good bits 200 rods bigger valves wade speedway grind put it in run it in on the dyno around the house and at the track run 4th gear in the first heat for one last bit of running in.
2nd heat its flying off the rear to 3rd in 2laps catching 2nd like nothing then pop pop pop shut it down.
take a look nothing serious from the look of it go out 3rd heat going all right pop pop pop again the bang drops a valve in no5.
there no piston left or cylinder wall and about 2nds off having electrical problems.
so good way to have 5g burnt in 4mins of racing
